ישן 28-08-07, 05:04   #1
למכירה KICKER KX 250.2 - amplifier
למכירה מגבר קיקר 2 ערוצים עדיין באחריות !
נמצא בקופסא המקורית שלו
Full specifications - KICKER KX 250.2 - amplifier
Manufacturer: Stillwater Designs and Audio, Inc
Part number: KX250.2
Audio SystemAudio system car audio typeAmplifier TV TunerTV tuner typeNone AmplifierAmplifier max output power / channel qty125 Watts x 2 Amplifier signal-to-noise ratio95 dB Amplifier input channel qty2 Amplifier output channel qty2 Amplifier output2-channel Amplifier input signal voltage0.17 - 5V, 0.34 - 10V Amplifier Output DetailsAmplifier output power / channel125 Watt, 250 Watt Amplifier output impedance / channel2 Ohm, 4 Ohm Amplifier output channel qty2, 1 CrossoverCrossover type2-way active crossover Crossover slope12 dB/octave Crossover low pass frequencies50 - 200 Hz Crossover high pass frequencies50 - 200 Hz Crossover bass boost frequency40 Hz Crossover bass boost gain0 to +18dB ConnectionsConnections typeAudio line-in, Audio line-out, Speakers input, Speakers output, DC power input Connections qty1 Connector typeRCA phono x 2, Screw-type
600 ש"ח
0545884818
אור
כל הזמנים קבועים כ GMT +3. השעה כרגע היא 11:43.
