פונטו ספייס 2001
הנסיכה שלי :-)
ישן 01-03-16, 14:05   #2
armus
תאריך הצטרפות: Mar 2015
הגלגלים שלי: פונטו elx
הודעות: 4
חיפוש בגוגל
תבדוק כבלי הצתה מחלה ידוע של פיאט
זה הכי הגיוני מכיוון שהוחלפו פלגים
Generic OBD Error Code Details for P0302
Cylinder 2 Misfire Detected
What does this mean?
OBD Code P0302refers to
A P0302 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #2.
Symptoms
Possible sumptoms of OBD code P0302
the engine may be harder to start the engine may stumble / stumble, and/or hesitate other symptoms may also be present
Causes
Possible causes of OBD code P0302
A code P0302 may mean that one or more of the following has happened: Faulty spark plug or wire Faulty coil (pack) Faulty oxygen sensor(s) Faulty fuel injector Burned exhaust valve Faulty catalytic converter(s) Running out of fuel Poor compression Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back. If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also
heard in other cases the problems were faulty fuel injectors
armus מנותק   הגב עם ציטוט
פיאט פונטו Mylife 2011 ORYAAKOV מכירה 0 21-09-15 07:42
למכירה פיאט פונטו איבו MYLIFE, ידני 1400 felixpes מכירה 2 14-03-15 22:43
מנורת מנוע פונטו 2005 HananPunto פונטו - טכני 5 25-11-13 21:30
שאלה| טיפול 90000 גרדנה 2008 fiat-punto גרנדה פונטו - טכני 5 07-05-12 17:15
נדלקה אצלי מנורת מנוע (פונטו אקטיב 04) PUNTO 2005 פונטו - טכני 8 06-07-10 17:15
כל הזמנים קבועים כ GMT +3. השעה כרגע היא 12:41.
