אודיו אודיו ומולטימדיה לרכב.
מפגשון באיקיאה - 15.6.12 :)
500 אבל בגדולללללל
ישן 18-09-09, 18:09   #1
מערכת חדשה ברכב :)
שלום חברים.
השבוע הרכבתי לבראבה שלי מערכת חדשה הכוללת:
* רדיודיסק של KENWOOD MP-4028
CD receiver with built-in amplifier (22 watts RMS/50 peak x 4 channels)
fold-down, detachable face with 2-color display
plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3, WMA, or AAC files)
System Q Sound Control: 6 preset EQ curves with bass, treble, and midrange controls
System E's crossover system (high- and low-pass filters)
satellite radio controls (SIRIUS or XM subscription, tuner, and antenna required to receive the satellite radio signal) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
HD Radio-ready
CD changer controls
optional auxiliary input (adapter required)
4-volt front, rear, and subwoofer preamp outputs
CR-2 tuner
18 FM/6 AM presets
clock
wireless remote
CD frequency response: 10-20,000 Hz
CD signal-to-noise ratio: 105 dB
FM sensitivity: 9.3 dBf
* קומפוננט של DRAGSTER DSX652.
6.5"2way speaker, 60W RMS, 120W Max power
Impedance 4 Ohm
Frequency responce 40-22kHz
Sensitivity 92dB
Crossover sloope 12dB
Tweeter attenuation 0/3dB
Mounting depth mid-bass 53mm
* רמקולים 6x9 Kenwood KFC-6989ie
Kenwood - 6" x 9" - Car Speaker - 4-way Design - 280 Watt Max Output Power 6" x 9" - 4-way - Car Speaker
* מגבר BOSS CX600 800Watt
MAX POWER, 2 OHM 200w x 4
RMS POWER, 4 OHM 100w x 4
MAX BRIDGED POWER, 4 OHM 500w x 2
SIGNAL-TO-NOISE RATIO 102 dB
THD 0.01%
DIMENSIONS: 11-7/8”W X 2-5/8 ”H X 13-3/8”L
CHAOS EXXTREME MOSFET AMP FEATURES
· Trimode operation
· Bridgeable
· Remote subwoofer level control
· Line and speaker level inputs
· Variable gain control
· Power and protection LEDs
· Variable lowpass crossover
· High pass crossover
· 0-+18dB variable bass boost
· MOSFET power supply
* מגבר BOSS BA-2900 1000Watt
* סבוופר 750Watt Lightning Audio - Bolt
דגם: B3.12.4
מפרט טכני:
- בעל עוצמה חזקה מאוד של 750W.
- עוצמה נומינלית RMS 150W .
- התנגדות 4ohm.
- רגישות 89db.
- טווח תדרים ענק של 20Hz-18kHz.
- גומי מסיליקון משופר.
- מימברנה עשויה מחומר פולי פרופילן
(I.M.P.P) המונע התייבשות הרמקול
ומאריך את חייו, ומצופות פיבר יקר המעניק
לרמקול איכות נקייה וצליל עמוק.
- גימור צהוב.
את ההרכבה עשיתי בעצמי:
- הבערת 3 זוגות RCA מהרדיודיסק למגברים.
- הבערת קבל REMOTE מהרדיודיסק למגברים.
- העברת קבל (+) מהמצבר למגברים.
- העברת קבלים מהקומפוננטים בדלתות למגברים.
- העברת קבל (-) ממרכב של הרכב למגברים.
- הותקנו 2 פלטות מרופדות מעץ מאחורי גב מושב אחורי ועל הפלטות הורכבו 2 מגברים.
- הותקן קומפוננט 6.5 בדלתות במקום רמקולים מקוריים (5x7). החורים שנשארו נסתמו עם חומר בידוד. הטוויטר הורכב בפינת הדשבורד במקום שמיועד לרמקולים 3.5, מכוסה פלסטיק כך שלא רואים את הטוויטר עצמו.
- הותקנו 2 רמקולים KENWOOD 6x9 במגש אחורי במקום רמקולים זולים 6x9.
- הקומפוננט חובר למגבר BOSS CX600 800Watt לערוצים 1 ו 2.
- 2 רמקולים KENWOOD 6x9 חוברו למגבר BOSS CX600 800Watt לערוצים 3 ו 4.
- סבוופר חובר BRIDGE למגבר BOSS BA-2900 1000Watt לערוצים 3 ו 4.
- חיבור RCA לרדיודיסק ולמגברים ללא מפצלים! הרדיודיסק מכיל 3 יציאות RCA.
(2xFront, 2xRear, 2xSubwoofer)
- ובסוף כמובן כיוונים, כיוונים וכיוונים
אם יש לכם שאלות או המלצות אתם מוזמנים להגיב ולהוסיף !
חג שמח ושנה טובה לכל חברי מועדון פיאט!
אלכסיי
שם:  Kenwood MP-4028.jpg
צפיות: 592
שם:  DRAGSTER DSX652 .jpg
צפיות: 620
גודל:  17.0 KB  לחץ על התמונה בשביל גרסא גדולה יותר
שם:  Kenwood KFC-6989ie.jpg
צפיות: 634
גודל:  17.9 KB  לחץ על התמונה בשביל גרסא גדולה יותר
שם:  BOSS CX600.jpg
צפיות: 607
גודל:  34.5 KB  לחץ על התמונה בשביל גרסא גדולה יותר
שם:  Lightning Audio - Bolt.jpg
צפיות: 540
גודל:  36.9 KB
נערך לאחרונה על ידי Lexxxa : 18-09-09 ב 18:28.
Lexxxa מנותק
ישן 18-09-09, 18:22   #2
התעניינתי במערכת כזאת אם אני לא טועה 543
מעוניין לשים טויטרים מקדימה הכוונה לפונטו דור 1 +2 רמקולים בדלתות הקדמיים(חורים).
המלצות לגבי הרמקולים יתקבלו בברכה.
לא מעוניין להוסיף שום תוספות
עלות המכשיר 650 ש"ח
ישן 18-09-09, 18:30   #3
Yair. הוספתי פרטים על מערכת. גם אני הרכבתי טוויטרים מקדימה.
ישן 18-09-09, 18:31   #4
יש לי מערכת דומה ברכב דגם ר"ד 312, שומעים מצויין גם בווליום גבוה. יש לי גם בבית עוד מכשיר דגם 241 חדש לחלוטין בקופסא, מרוב שאני מרוצה אז כשהנוכחי יתקלקל אני אתקין את מה שיש לי בקופסא.
איכות השמיעה של מכשירי הר"ד של קנווד היא מעולה, גם מה- CD, גם מהרדיו וגם מקבצי AUX.
ישן 18-09-09, 18:53   #5
asaf123
תאריך הצטרפות: Mar 2008
הגלגלים שלי: פיאט אונו 94
הודעות: 288
שלח הודעה דרך MSN ל asaf123
גם לי יש דגם דומה של קנווד אם אפשר לשאול מאיפה קניתם את המחבר של AUX ומה מחירו?
asaf123 מנותק   הגב עם ציטוט
ישן 18-09-09, 20:50   #6
asaf123
באיזה מחבר מדובר?
אני השתמשתי בכל היציאות של רדיודיסק (3x2) לצורך הגברה של קומפוננט(Front), רמקולים אחוריים (Rear) וסבוופר (SW). כך שלא נשארו לי שום יציאות/כניסות של RCA בר"ד.
ישן 18-09-09, 21:05   #7
במקור פורסם על ידי asaf123 צפה בהודעה
אני לא קניתי אותו, הוצאתי אותו מתוך אריזה של MP4 שקיבלתי מתנה.
ישן 19-09-09, 00:52   #8
רוצה לחדד
איזה גודל טויטר מקדימה.
איזה גודל רמקולים בדלתות.
איזה סוגי רמקולים אם חייב גם קנווד ואיזה דגם
פיאט חדשה?. רפי לין פיאט כללי 8 17-08-09 13:11
אונו 93 כמו חדשה מכירה 7 25-08-07 22:25
חדשה פה.... מועדון פיאט ישראל 8 05-01-06 16:43
מכונית חדשה פיאט כללי 10 27-12-05 15:27
כל הזמנים קבועים כ GMT +3. השעה כרגע היא 09:48.
