ישן 03-07-14, 18:54   #33
chesh
האווטאר של chesh
מיקום: ראשל"צ
הגלגלים שלי: פונטו 96
הודעות: 1,033
לא יהיו, יש לך אופציה לעשות איפוס והסתגלות מחדש למחשב רכב בלשונית האחרונה.
נסה אותה אך איני אחראי.
"In some Marelli systems, the ECU is able to manage a self-adaptive strategy that allows recognizing the motor changes due to settling, wear, replacement of propulsor parts and components (mechanical, electronic), motor shaft phonic wheel learning (59F, IAW5SF3), modifying the basic mapping. The function clears the permanent log of such calibrations.
Marelli 59F (Punto 99, Seicento, Panda, Doblo, etc.), Marelli IAW5SF3 (Grande Punto):
-This is indicated by the flashing MIL light; it will turn off and the procedure will be completed proceeding as follows:
1) warm up the engine
2) increase the engine speed three times to 4500RPM and keep it for 3 seconds each time.
Marelli 1AF (Bravo, Brava, Marea):
- any motor malfunction (for ex. irregular minimum, emissions out of limit, lack of power, incorrect operation, etc.) will be eliminated following the procedure and PREVIOUSLY repairing and clearing the fault codes."
לקוח מהתוכנה.
chesh מנותק   הגב עם ציטוט
